주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.6 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.2 GHz). 2013년 2월 13일에 출시되었습니다.
119 질문 전체 보기
What is up with my Display?
Guys this is what happened to my Macbook Pro and I was wondering if anyone knows what is the best solution
1) Opened Macbook one morning after making some coffee and the screen was white with a gray halo around it… it was just frozen there.
2) I restarted the Mac and the screen was now totally black. I plugged it into my external Asus Display and found the laptop itself to be functioning properly!! apart from display
3) I went into system preferences “display” and it wont even identify the macbook monitor only the external one
4) Webcam works fine and even lights up when it is on
5) The Back apple light is always off
6) I have tried all software resets and nothing works so this is defo a hardware issue
How can I for sure fix this problem? What should I order and do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Aim a flash light in through the lids Apple Logo, do you see a faint image of your desktop and its icons?
Hi Dan. There is no faint images at all. In system preferences it won't even recognise the display.
댓글 달기
답변 2개
가장 유용한 답변
This looks like the same issue: MacBook Pro won't detect internal display
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
@luiz.pinheiro83 - At this point you’ll need to pop the bottom cover and inspect the internal display connection to see if it’s damaged if not you’ll need a new display assembly.
Follow thins guide to Step 9 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement then jump down to Step 14 inspect the connection thoroughly.
Sadly, If you don’t see any then you’ll need to get a new display assembly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
luiz.pinheiro83 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 60
