주요 콘텐츠로 건너뛰기
The digital camera was released by Panasonic in July of 2016. The Panasonic Lumix DMC-ZS60 has 18-megapixels and wifi mobile device connectivity.
4 질문 전체 보기
Popping/Cracking Noise when zooming
When the camera is powered on, the lens makes a small cracking noise while extending. Other than that it works normally. How can I fix this?
Thank You!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Andrew Jensen  sounds like you may have some dirt/debris in there. Other than disassembling the lens and trying to clean it, which is a challenge without proper manual, there really is not anything you can do to fix it. Only other thing is to replace the lens Panasonic Lumix DMC-ZS60 Camera Lens Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andrew Jensen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 633
