주요 콘텐츠로 건너뛰기
A2115 / 2019 / 프로세서 3.0GHz 6코어 i5부터 최대 3.6GHz 8코어 i9까지. 2019년 3월 19일 출시.
20 질문 전체 보기
Vertical Black Line on iMac Screen
I swapped my 27" iMac 2019 model 's HDD to Samsung 1TB SSD. Original aim is successful and the iMac is blazing fast now.
I connected it back and closed the iMac. When I powered up there was a black vertical line on the left of the screen. I changed the Lvds cable but still the same issue.
Any help would be much appreciated thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Ouch! Sadly you managed to damage the display in the process of taking it off.
Either you used a tool which went in too deep or you pried up a bit too hard. Don’t feel bad the first one I worked on (before we even had the guides or proper tools) I messed up too!
Review the guide here to see where you messed up and getting a replacement iMac Intel 27" Retina 5K Display Display Replacement
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
I have a similar issue after a similiar upgrade. It’s a thin black line. Does that mean a screen replacement?
Ahh well. I’ll see how long I can ignore it for. Thanks.
This is 100% correct. Prying the screen too hard and separating the glass layer from the LCD layer will cause things like this.
The device is still 100% usable. You can lose your mouse in the black and still click on things that are there, or you can do your best to ignore it, but the only way to fix this is to replace the screen.
Thanks. Yep, it’s not worth the cost for me as I use the iMac for work and I have a pc for gaming. I’d be more concerned if it was also my gaming rig. But a black line is fine for reviewing spreadsheets and writing emails! :)
댓글 1개 더보기
댓글 달기
답변을 추가하세요
edoudji2000 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 249
