주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
Turn off by it self,and won't turn on.
When use the mac for half a hour,it will turn off by itself, and should waiting for one hour or more,can turn it on.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
At first ,i thought it will be overheating,after i checked everything,no overheating.and today i checked the power supply, that has problem.thank you everybody.
댓글 달기
답변 2개
선택된 답변
Sounds like something is overheating and shutting you down. Take the cover off and observe the diagnostic LEDs to the right of the RAM slots (this may be covered by a piece of black electrical tape). Jason may be right about the power supply, if so none or just the first LED will remain on after it shuts down.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
가장 유용한 답변
It's hard to say based on the info you have provided, but I think you need to replace the Power Supply. You should do all of the normal tests such as resetting the SMC/SMU, reset the PRAM, and remove and reseat/replace the RAM. HTH. :)`
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
tomma 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 739
