주요 콘텐츠로 건너뛰기
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 질문 전체 보기
The sensing blink light is still flashing
I've done everything step by step as shown up top and the sensing blink light is still flashing what should or else I do
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@Bryen Aareon If the only light blinking is the sensing LED then the sensor has found an issue in the basket/drive This could be a bad shifter, worn hub assembly or an item of clothing that managed to get between the inner and outer tub. The inner tub engages the clutch by dropping down. This washer checks the position of the basket at the beginning of wash before it fills. That’s the noise you hear the first few minutes after you press start. Flashing sensor means it detected a problem with the positioning of the basket.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Bryen Aareon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 23
30일 전: 105
전체 시간: 4,243
