Water will continue to fill into the drum during cycles.
The water will continue to fill during the wash and rinse cycle. I have to turn the water off at the wall to stop. Is this the water inlet valve going out?
좋은 질문 입니까?
좋은 질문 입니까?
Hi @jpaul1990 ,
What is the model number of the washer?
It sounds more like the water level pressure sensor switch is faulty or the hose that connects to it has come off or is loose.
해당 답변은 도움이 되었습니까?
Thanks @jayeff it also drips a steady stream of usually hot water even after the cycle is complete is why I was thinking inlet valve. I will look for the model number
@jpaul1990 this "lso drips a steady stream of usually hot water " does sound like a bad water inlet valve.
I agree that it may be the hot water inlet solenoid.
Search online for "(insert washing machine model number) parts" to find suppliers. The major ones are partselect.com, searspartsdirect.com and repair clinic.com
My answer above was based on what you said at first. There was no mention about it happening when not in use or even that it was only the hot water.
You only said:
"Water will continue to fill into the drum during cycles."
"The water will continue to fill during the wash and rinse cycle"
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 43
