주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Can I remove logicboard and put it into A1599 housing? (IPAD mini 3)
Hey guys,
I’ve got a scenario here.
If I take the logicboard of an Ipad Mini 3 (Model A1600; wifi + Cellular), would it work if put it into the housing the IPAD mini 3 (Model A1599; just wifi) ?
I just want check if this is doable.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
This isn’t something I have tried myself but I suspect it would. The iPad mini logic boards aren’t screwed into the housing like iPhones are so you don’t have to worry about proper placement of screw holes. The main difference between the two versions of logic board is that the WiFi only board has a large hole where the RF infrastructure would be. All of the other flexes are universal.
So if you already have the two boards, I would certainly give it a try.
Replace a logic board (motherboard) compatible with the 3rd Generation iPad mini Wi-Fi model. Fix processing issues like unexpected shutdowns, reboots or water damage. 이미지
제품
iPad mini 3 (Wi-Fi) Logic Board
$69.99
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Ckalable upflow 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 395
