주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
155 질문 전체 보기
NFC and Bluetooth problems
Where is this located? Dropped the phone on the top in an otter box but now the NFC doesn’t work and Bluetooth audio streaming keeps dropping and reconnecting. Bluetooth phone calls are fine. Flashlight is also spotty works and doesn’t sometimes. Is this a connector or a brass pin connector or a bad chip? Already had this issue and phone was replaced under limited warranty. It’s happening again after a drop. I work in the field. Update: it drops connection when the top of the phone is sandwiched lightly Around the area of the mute switch. If I squeeze it, it drops and comes back after a few seconds. It’s a full drop connection
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
You should check the flex connectors are all seated properly. It does sound like a connection problem and the 11 Max is a layered board. The solder they use to connect the two layers in my standards is poor quality and the phone only needs a slight drop for the solder balls to crack and become oxidised.
I think you will have to have it looked at by a reputable repairer who would separate the board, check the pads than re-ball it with some quality solder.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Matt Bray 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 514
