The 5th Generation Hilux introduced in 1988, produced a longer-wheelbase option, 3,099 mm (122 in) rather than 2,616 mm (103 in) for the regular wheelbase. Its one-piece cargo-box walls eliminated the rust-prone seams that were found in earlier models.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
multitasking974 exactly what have you checked? Do you have fuel going into the cylinders? Do you have spark when the engine turns over? did you check your oil level? Is it sufficient?
oldturkey03 의
i checked out everything you ask....nothing...and mechanic around here want lot of $ just for checking.
multitasking974 의
