주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
135 질문 전체 보기
11 Pro Max constantly rebooting after wireless charger replacement
Is the wireless charger a minimum requirement for the iPhone 11 Pro Max to stay on? Does anyone know what parts this phone needs to keep running? Ive run it with everything disconnected bar battery and screen and it still shuts off.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Seeing as how no one else has chimed in, I’ll take a stab at it.
As far as I know, a minimum configuration of battery screen and dock (to permit connect-to-boot) allows all devices to boot properly (you could exclude the dock and jump start it with tweezers). I haven’t tested this on a 11 Pro Max but I don’t see any reason why it shouldn’t.
The question here might be if the logic board was damaged, either when disassembled (I doubt it, you are an experienced tech) or the circuitry was damaged before hand, hence why you were asked to replace the coil. Give us a bit of background on the device prior to repair.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I figured as much, the phone was bent AF, pretty sure it’s the charging IC thats cooked as the X line seem to do the same when its dead. Just wanted to make sure I didn’t miss anything.
The battery has two connectors, one to the main board and one to what looks like a sub board on the charging port flex, maybe a working flex is a necessity as well?
댓글 달기
귀하의 답변을 추가하세요
Renato 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 98
