주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
broke the "small antenna" during battery change procedure
During the battery change procedure, which went well for the most part, I broke the “small antenna cable” identified in section 17. Didn’t notice until reassembly. Since it is not the GPS nor the WI-FI antenna, I’m unclear exactly what I will find inoperative once I finish. Is a replacement available? (I was confused by the difference in picture between the Wi-Fi model and mine. Oh well.)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I’ve never used the Cellular capabilities of the mini 2, so will I miss anything if I do nothing? Will the mini constantly remind me that the antenna is broken? Note: I bought the cellular version to get the improved GPS capabilities.
I’m off now to get some 90% isopropyl to clean the gunk left behind from the glue.
I don't believe so.
댓글 달기
답변 1개
선택된 답변
It is the Right Cellular Antenna. With a damaged antenna, you will have less (or no) cellular sugnal.
iPad mini & mini 2 Right Cellular Antenna 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Leon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 59
