주요 콘텐츠로 건너뛰기
모델 A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
50 질문 전체 보기
2014 iMac Won't turn on and already replaced power supply
So about a year ago my daughter hit the screen on my iMac. it instantly shut off never to power up again.
The 1st Diagnostic LED on the logic board is lit but I can’t get the 2nd LED to turn on. I bought a replacement power supply and installed it with no change.
I also replaced the PRAM button battery and again no change. I verified the power button works using my multimeter and ohming it.
Not sure what else I can do beside a new logic board which at this point cost’s an outrageous amount for a 6 year old computer.
Any additional troubleshooting tips would be very appreciated!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
From Apples service manual:
LED #2 - Indicates that computer is turned on. This LED will be ON as long as computer is turned on (but is not asleep) and power supply and voltage regulators are working correctly.
The ‘voltage regulators’ are on the logic board. That would be my direction of diagnostics.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brandon Riskey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 88
