주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
207 질문 전체 보기
Why is iPad constantly rebooting post battery replacement? See video
Problem: iPad Mini 2 just turns off seconds after turning on and then continues to reboot. At each alternate reboot the screen flashes red before shutting off and turning on again. Please see the short video. It shows me turning the iPad Mini 2 on and shows the iPad rebooting several times.
I am able to turn off the iPad Mini 2 by holding down the power button.
Context: I just replaced the battery of this Wi-Fi only iPad Mini 2.
Possible Useful Info: This iPad Mini 2 was repaired previously. When I opened it up the LCD Shield was bent and screws meant to hold down the LCD Shield actually went through the the metal LCD Shield.
When I received the iPad the battery was completely swollen and had lifted the front screen aka digitizer and did not turn on.
The owner of this iPad Mini 2 was not 100% sure it was a battery issue although seemed like the likely culprit.
My thanks to the iFixit community for your help.
Update October 26, 2020:
  1. I’ve added photos of the motherboard. Both as it was when I installed the battery and then after taking out the motherboard itself.
  2. Additionally owner did say that the reboot cycle with the red screen did occur before the iPad died from a bad battery. It had a charge battery signal with the constant reboot, so they thought it was just a battery issue. Obviously it was not.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Do you by any chance know the OS it has? I recall that there was a bug on some version of iOS 10 that caused some devices to constantly restart itself on boot like this (had a 5S with the same processor do the same, ended up restoring and updating it to iOS 12).
I doubt it would be a problem with the LCD shield since if it was indeed faulty atleast you would've seen something other than the apple.
Amatsuda, The owner does not remember what version of iOS. They haven’t used it for at least a year
@edd1e I guess that was at my fault. Realized it wan't even an issue with the software (techincally).
의견 추가하세요
답변 2개
가장 유용한 답변
Roman has made an excellent suggestion but to me, the red flash is worrisome; this is usually associated with NAND issues. The NAND memory IC would have to be de-soldered, re-programmed and then reballed. Certainly not a DIY fix.
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Would be willing to give it a try. Nothing to lose at this point and I might learn something regardless of outcome. I've uploaded pics of the logic board. Thank you for your response.
All the magic is occurring underneath the shiny shield.
의견 추가하세요
Hello Eddie,
Open the iPad and have a look around the battery connector, there should be tiny little components around it. If one of them is missing it would cause the iPad to reboot by itself. If the shields were off already it could mean that there’s more faults with it. Would help if you could post pictures of the motherboard
해당 답변은 도움이 되었습니까?
점수 3
댓글:
I've uploaded pics of the motherboard. Thanks for your helpful response. Hopefully this helps. Thank you for your input.
의견 추가하세요
귀하의 답변을 추가하십시오
Eddie de la Rosa 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 62
