주요 콘텐츠로 건너뛰기
납땜은 두 금속 조각 사이에 다른 필러 금속을 녹여 두 금속을 연결하는 방법입니다. 납땜에는 여러 가지 종류가 있지만 이 글에서는 전기 납땜의 기본을 알려드리고자 합니다.
Need help with metal connector soldering repair
Heya Group,
I really need some help.
I bought a collectors statue from North America and shipped to Mentone, Victoria.
The statue requires assembly and has LED light display throughout.
Part of the assembly is connecting parts to the slot in the base of the statue.
The slot has a connector which has 1 broken prong and obviously does not allow the top half of the statue to light up.
The statue takes 6 AA batteries at the rear of the base and the broken metal connector that connects to the top half of the statue is in the center slot.
Please see attached photos and please if anyone can tell me who can repair the broken connector. I have phoned around to many places (phone repair, PC repair) and have hit dead ends.
Can anyone please help. :-(
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
You may have to replace the entire connector assembly, as soldering the connector pin back will most probably not last if the unit is disassembled often
Here’s a link that show various types of spring loaded connectors that may be adaptable to your situation.
Here is perhaps one. Its datasheet shows that it has a 30V DC 3A/contact rating so the power specifications should also be considered when selecting if this is not sufficient.
Look for both male and female so that they”mate” when joined. Here’s a 4 pin female connector just to let you see. (couldn’t find the 2 pin but it should be there).
Just an idea.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thank you so much for your reply jayeff.
The statue will not be disassembled ever once connector is repaired so I'm hoping that the connector can be repaired by some soldering. I just need to find someone that can do it as I'm not confident to do it myself..
@sickbunny1 - Spring leaf contacts like the one you have here that is broken can't be soldered back on. All you can do is replace it.
You would need to carefully open the connector to gain access to the broken piece still inside then using a piece of spring bronze cut out a replacement matching the full part. Or, as @jayeff recommended just replace the entire connector (which is what I would do).
Sadly, there is no way to solder things here.
댓글 달기
답변을 추가하세요
Glenn Woods 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 149
