주요 콘텐츠로 건너뛰기
2006년 11월 북미에서 출시된 Wii는 인터넷 연결을 직접 지원하는 닌텐도 최초의 가정용 콘솔로, 온라인 게임과 Wii 숍 채널을 통해 게임 및 미디어 애플리케이션의 디지털 유통을 모두 지원했습니다.
Why is my Wii producing a dark picture?
I got out my old Wii that worked fine for the longest time with no issue, one day I go to turn it one, and the picture displayed is very dim and hard to see but there is still one. I know it is not the tv or the power cable as my grandparent’s Wii still works perfectly and theirs still works fine with my cables and on my tv. What could be the issue and how would I fix it. If I can’t fix it is it possible to get another Wii and transfer the data over to that new one?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 5개
가장 유용한 답변
Hi!
Which cables are you using? The regular AV cables? What you can do: Buy and try the composite cables. Perhaps this will work.
Side-Note: It also could be your AV port which is damaged or something went wrong with the GPU.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I am using composite cables, and the port does not look damaged, so could the only remaining thing be the GPU?
Could you otherwise try the regular AV cables? Sometimes mixing it up (composite) is causing this.
댓글 달기
MattKC did a video on dim wii video! though it is really difficult to fix if you plan on doing it yourself. https://youtu.be/sdWmm33VzBM
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
it might have something to do with the video capacitors on the motherboard. They're connected to the AV chip and port. though replacing the bad capacitors is really difficult.
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Maybe buy a second AV cable to test that it's not the cable itself. If that does nothing, try a nice old power wash of a q-tip and alcohol, if neither work, just follow MattKC's video
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Why can't the color come in on the Wii game it dose at my aunt's but not on my Wii system I am borrowing her Wii game
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
hexagonalyeti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 151
전체 시간: 14,341
