주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Garmin GPS devices.
324 질문 전체 보기
dropped on floor maps have gone .
dropped on floor maps went off to be replaced by coloured lines.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Robert, if you have colored line on your display, try a reset first and see if that makes a difference. If not, I would suggest you open your device. Check for tore cables and loose connections. Worst case scenario, you will need a new LCD....
Start with the device OFF and unplugged from the power source.
Use your index finger to press and hold the top right corner of the touchscreen.
Power the device ON while continuing to press and hold your finger to the top right corner of the touchscreen.
After the device powers ON, you will see the message: Do you really want to erase all user data?
When this message displays, remove your finger from the top right of the touchscreen and touch Yes.
The device will now go through the Reset.
Follow the onscreen instructions to set up your nüvi. http://www.factory-reset.com/wiki/Nuvi_3...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Following these instructions, my Nuvi only said can't unlock maps with an ok bar at the bottom of the screen. The above instructions don't work for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 287
