주요 콘텐츠로 건너뛰기
Hybrid laptop/tablet manufactured by Microsoft. Released November 2017.
38 질문 전체 보기
After replaced Keyboard battery don't charging
Hi 4 all .. i replaced keyboard battery for my surface book 2 model 1832 .. with same code of old dead battery but the new battery don't charging … how could solve this problem please …
  • I tried uninstalling the battery drivers not work too.
  • When turn device on and the charger connected to it .. device work normally
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Since you replaced the battery make sure it’s plugged in securely and the black connector is pushed all the way into the port on the mainboard. It may be the ac adapter/charger you are using, make sure the charger is fine as well.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@angeld
I check the connector many times and test charging with two ac adapters
But same problem no charging ..
Surface work with direct power only ..
댓글 달기
귀하의 답변을 추가하세요
Gaith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 183
