주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Flat flex cable connecting top right cellular antenna to motherboard
I noticed when repairing the top right cellular antenna that the little flat flex cable that connects underneath to the motherboard is damaged. This little flat cable is something you can’t order anywhere except to buy a damaged overpriced Ipad mini 3 to pull that part off. My question is this…..Can I simply just use a small wifi or Bluetooth cable and connect it that way? It’s the same little round connector.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
hello Frank,
even more :-) You can cut off the damaged connector and solder directly to the board (socket of this connection). If this is your iPad, remember that it is permanently connected. Also remember that the cable has the appropriate resistance. If it is too big or too small, the antenna will not work effectively.
  • regards,
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
frank 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 44
전체 시간: 260
