주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
872 질문 전체 보기
iPhone Microphone Issues - works on camera and Siri, but not on calls
Hello,
I have a similar issue to someone else on here, the microphones on my iPhone 8 only appears to work while doing specific things - the microphone works fine with Siri, Front and Rear facing video, but doesn’t work for calls on both speaker and earpiece, pretty sure FaceTime & voice memos records a flat line and plays a cracking sound. I am thinking it is the bottom microphone that isn’t working, and am hoping it is not logic board.
As for history; the screen and back are cracked (bought it like this) particularly near the dock section on the back. However, everything else works fine (as far as I can tell) and I opened the phone up and all water damage indicators are white and the phone is mostly clean with little dust.
Has anyone found a solution yet? I have ordered a new replacement housing with parts so it comes with a new dock connector and mic so I will see if that works!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Microphone is most probably disabled for phone calls. Go to settings to see if this might be the problem, or go to the phone app and check the setting there.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Bottom microphone might be broken or not making good contact with the logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
TmG 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 44
전체 시간: 1,716
