주요 콘텐츠로 건너뛰기
Apple의 외장 광학 드라이브는 기본적으로 MacBook Air SuperDrive의 리브랜딩입니다.
35 질문 전체 보기
Can not find Super Drive in Finder or Disk Utility.
Super Drive was recently plugged into a non apple laptop (did not work). When I tried to use it in my MacBook Air using Satechi Aluminium USB-C Multiport Pro Adapter it says USB Accessory needs power. (It worked before) Can the Super drive be fixed or is it best to just buy a new one??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It might be repairable! It depends on your skills and getting access to the needed parts.
When you plugged it in to the other systems USB port you some how damaged the logic (I wouldn’t use that systems USB port as it could damage something else)
Here’s a guide which will get you in and access to the logic board Apple USB SuperDrive Optical Drive Replacement
Checking the discreet SMT devices is about all you can do unless you can get a parts unit to swap out the logic board.
Otherwise you’ll need to get a replacement drive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you for the quick response. I’ll try this and if it doesn’t work for me I’ll replace it.. Thank you xx
Don't forget to accept the answer - Thanks!
댓글 달기
귀하의 답변을 추가하세요
Terene Sinckler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 304
