주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Asus Republic of Gamers G751 laptops released from late 2014 to early 2016. Related model numbers: G751JL, G751J, G751JM, G751JT, and G751JY.
29 질문 전체 보기
Exposed battery wire: okay to use electrical tape?
Problem: I replaced the OEM battery with a generic one from iFixit. Its individually wrapped “rainbow” wires weren’t shaped like the OEM battery’s were, preventing them from laying flat. They obstructed a case screw. I didn’t realize this until I looked to see why the screw wasn’t going in, and then saw the slightly frayed cable.
Question: Is wrapping each exposed wire of the battery cable with electrical tape okay? Aside from the added bulk in a tight space.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@vermilion_beats as long as it is just frayed, yes it is okay. Just make sure it stays well insulated from any metal, component etc.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
The wire might be a bit scratched from the multiple screw-in attempts. I can't fix things for a few days, so I can't check. It shouldn't be in danger of breaking though. I'm going to use overlapping vinyl electrical tape on the wires, and then maybe tape them to the motherboard like the OEM battery.
I'll check back with the results later.
Update: Ordered another battery and replaced it. I could see dull gray, so I think that the wire was basically exposed. Thank you for the help!
댓글 달기
귀하의 답변을 추가하세요
Vermilion 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 823
