주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
122 질문 전체 보기
I Wiped my Phone Screen with 75% Alcohol please help
I’m not sure it’s due to this but recently my iPhone screen has been dimming even I’m still using it. I sprayed it one time on the tissue and gently wiped on just the glass protection part of the screen. Do you think my phone is damaged? It doesn’t happen all the time, it happens sometimes. I used 75% cleaning product not the type for medical use so I’m worried. How can I check if my phones ok?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I think it should be fine. The light dimming may just be automatic dimmer
댓글 달기
답변 2개
가장 유용한 답변
As a repair shop I use rubbing alcohol often to clean and sanitize devices. I don’t think you damaged your screen. As the comment mentioned above, you probably have auto brightness enabled or it could be malfunctioning. If I’m not mistaken you can turn off auto brightness by turning off TrueTone. Are you able to manually adjust the screen’s brightness without any issues?
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
To empisize on this, I know someone who has the iPhone 11 and they occasionally and agenst my suggestions, wash there screen with straight water on a paper towel
@Tsar_ Bomba as long as they're not running it under the faucet and use a damp paper towel they should be safe.
댓글 달기
I’ve been using 75% alcohol sprayed onto a good microfiber cloth to clean both my MacBook Air M1 and my iPhone 11 Pro Max. This process works great for both devices and I’ve never had a problem. I agree with the above comments in that you either have auto-brightness turned on or the sensor is damaged (rare). As stated above, try turning off “True Tone” which will de-activate “Auto-Brightness”.
Good Luck!
Jeff Broome
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 74
전체 시간: 1,727
