Front digitizer+lcd unit and the back panel compatible with iPhone 4S?
I am wondering if the iPhone 4 and 4s back panel and front digitizer assembly are interchangeable. There are an abundance of these parts floating around on ebay and I would like to know if parts available for the 4 will fit the 4s.
In the teardown it is mentioned that the tab locations for the digitizer is identical to the GSM version, does that mean most of the replacement parts available for the iPhone 4 will fit the 4s?
Update
thanks for your quick reply, however, I would like to hear a little more about your experience. perhaps you can elaborate a little more. which model iPhone did you compare this to? and what exactly was the problem? in the teardown, it is mentioned the tab alignments are compatible with the gsm iPhone 4, is the LCD and digitizer connector the issue?
좋은 질문 입니까?
댓글 2개
I just got a call to replace the front AND back glass on the 4S. I will have a definitive answer for you all tomorrow. The repair is scheduled for 6:00 Pacific time. Wish me luck!!
magistry 의
Does someone know if the iPhone 4 lcd/digitizer will work correctly when connected to the 4s? (regardless of where the tabs are) seems like every one is concerned about where the tabs are, when no one has actually mentioned if it works or not.
Ryan 의
