주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2003년형부터 2007년형까지 1세대 Nissan Murano에 대한 수리 안내서 및 지원 자료입니다.
when I pour water in my radiator it runs to mh crackcase drain plug
My problem is when i pour water in my radiator it runs to mh crackcase drain plug non stop flow.its been hydrolocked..still starts with a loid rattle noise…can anybody help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Most probable is either a failed gasket or a cracked block. Water its heavier than oil, so it will go to the bottom of the drain pan.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Could it be a oil coolier line
의
댓글 달기
That is a symptom not the problem. Sounds like a blown head gasket at best and at worst a cracked block or maybe a thrown rod that has resulted in a compromised engine water jacket. You could start with removing cylinder head(s) to see if the problem is obviously limited to a head gasket issue. Either way this will be a major expense to repair or replace the engine in all probability. Good luck sir.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
That is fast if its a blown head gasket it but could be a cracked block i hope..if i could fix it then i think it will come right.it still seems to run on all 8 cylinders jus a rattle and not much oil flowing to the top
의
These vehicles come with either a v6 or an i4 engine only as manufactured. If it pours out the drain plug as fast as you pour it in, then the engine is likely unrepairable.
의
댓글 달기
답변을 추가하세요
leon poipoi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 28
전체 시간: 363
