주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1149 질문 전체 보기
internal display only works when an external display is connected
the internal display only works when a external via HDMI is connected, at that time both internal and external work perfectly, disconnect external and nothing but garbled horizontal lines, replaced logic board and display with no positive result still same symptoms
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It was the LCD after all , I originally tried what was supposed to be a known Good lcd and then was unsure after symptoms did not change.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Your logic board has a problem somewhere within the video logic. What you are seeing is the loading of HDMI port appears to act as a signal load as the internal one has failed.
Someone with good board diagnostic & micro soldering should be able to fix your logic board. Otherwise you’ll need a new logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 7개:
I thought the same thing at the beginning but after REPLACING the logic board as I mentioned the problem is unchanged, I also replaced the retina Display and nothing changed, the only thing that i have not changed is the daughter board
@appleheadrepair - I'm wondering if you have a bad ground. What happens when your system is not connected to the MacSafe charger is that acting differently?
same exact result already checked that and swapped ssd to rule out any Apple OS X quirks, something happens when the hdmi port requests connection . This is very odd situation .
I will check the I/O (daughterboard) in the morning and see if there is possibly some kind of foreign debris in the hdmi port or damage there, but then its highly unlikely to be the culprit. Just plugging in the hdmi cable does nothing, it has to complete the connection and see the extra display, which originally I was sure meant the GPU switching got messed up but a complete replacement board same exact symptoms ??
@appleheadrepair - The I/O cable ??
2 댓글 더보기
댓글 달기
귀하의 답변을 추가하세요
appleheadrepair 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 79
