Freezer display temp does not match actual temp
I have a GE profit refrigerator/freezer. The user interface displays the actual temp of the freezer as -9*, but the actual temp is 20*. I have replaced both thermistors and the control board. It is still doing it. I can put the user interface into test mode and everything tests normally. I set it to prechill mode and it will get to the correct temp in the freezer, and read the correct temp for a while. But ultimately the user display will go back to registering -9* as the actual temp but it will only be 20*.
Also, there are no leaks in the system. The coolant levels are normal. Does anyone have any ideas?
좋은 질문 입니까?
Hi @cjmitchell ,
What is the model number of the refrigerator?
What is the refrigerator compartment temperature like?
Just wondering how you checked the "coolant" levels as it is a sealed refrigerant system? Do you mean the high/low pressures in the sealed system?
jayeff 의
MODEL GSHS6HGDSS. I should have been more specific: the sealed system was checked by an appliance repairman and was fine. The refrigerator temp stays within a few degrees of what it is set on the display (37*).
Chris Mitchell 의
