주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Why not only vibrate? I'm looking for a way.
In the process of replacing the battery, I accidentally tore the cable of the taptic engine. I got a new part and installed it, but all the other functions are working, only the vibration is not working.
I also bought a new charging dock and replaced it. There is nothing wrong with the home button. Charging, phone, camera, speaker, etc. all work normally.
However, even if I purchase and install a new taptic engine, it is still not vibrating.
업데이트 (2021년 01월 08일)
After several months, a new phase has come.
In the process of reassembling the Taptic engine, I tried working with the power on, and surprisingly, the vibration of the home button came to life.
However, other vibrations sound only once very briefly and not again.
Still, vibration survived when switching ringtone/silent, and various vibration functions were activated.
The only problem is that when I reboot the iPhone, all vibration functions disappear completely again.
Whenever that happens, just remove the taptic connector after disassembling it with the power turned on, and then the vibration will survive.
At the moment, I think it is the best measure, so I am satisfied and in use. However, the cause is still unknown.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
One thing you could try to rule out a software issue, would be setting it back to factory settings.
As there’s no problem with other functionalities, there could be a contact problem where the tapic engine and the contact points on the flex.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Still couldn't solve it. I tried to reset it, but still only vibration is not working. Since the Lightning Connector is also new, I think there is no problem with the taptic and the contact part.
In this case, could there be a problem with the motherboard?
thank you for the reply.
@jeresys Since your phone works perfectly other than the vibration, it barely has problem with the motherboard, test the vibrator before a replacement.
댓글 달기
귀하의 답변을 추가하세요
Shinung Park 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 68
