주요 콘텐츠로 건너뛰기
Apple의 PowerBook 노트북 라인은 전문가와 파워 유저를 위해 만들었습니다. PowerBook 라인은 PowerBook 100, Duo, 500 및 5300 Series; PowerBook 1400, 2400, 3400; PowerBook G3, G4 Titanium 및 G4 Aluminum으로 구성됩니다.
"E" key doesn't work on PowerBook
Hi! I've tried cleaning the contacts (only by removing the key cover) with Caig DeOxit several times but to no avail. Is this a dirty contact that must be cleaned by full disassembly? Any ideas? Thank you very much!
Collin
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi! When the key cover is off, and you press down on the bouncy piece in the center of the key, does that work? If so, it's a mechanical issue that may require you replace the plastic scissor contraption under the cover (you can get these and keys themselves on eBay for a few dollars), and if not, likely an electrical trace on the keyboard has been crimped/cut/etc., and you'll need a new keyboard.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks! Alas, the key does not work with the cover off, or even if I press directly on the contact with a probe. It sounds like I need a new keyboard. Glad there are parts and instructions here in order to do the job, even if keyboards are a little pricey. Thanks for your help!
댓글 달기
답변을 추가하세요
Collin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 1,562
