주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Why won’t my right side of my new screen replacement work?
I just bought to a new replacement screen and now my right side randomly stops working. The old screen was crushed by a chair, can anything inside the phone cause it to hurt the new screen
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
hello Idalla,
No, it can not. You have probably inserted the touch connector incorrectly or the touch function has been damaged. This is most often the first. Disconnect the connectors again (start by disconnecting the power supply - always) and try. Don't press, you will hear a soft "click". This means that everything is in place. Connect the battery and check. If touch cannot be restored, it could be a mechanical failure on the other (bottom side of the motherboard) side. Do not put anything under the connectors (sometimes people use a flat screwdriver to remove the contact - this is a mistake that costs quite a lot).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Idalla 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 32
