주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Asus Republic of Gamers G751 laptops released from late 2014 to early 2016. Related model numbers: G751JL, G751J, G751JM, G751JT, and G751JY.
29 질문 전체 보기
Asus G751JY Laptop won't power on (no lights)
Model: G751JY-T7094H
Hi,
The laptop stopped suddenly while in use and since I couldn’t start it again. No lights on even when plugged in. I tested the power supply and the multimeter indicated 19.5v as expected. I also tested the battery (not sure though if it is meaningful) and the expected voltage was what I read. I replaced the CMOS battery (I don’t know if this was necessary).
I need some guidance about what to replace. Which tests can I perform to identify the culprit? A new motherboard is pricy. My battery is old (5 years with daily usage), can a dead battery prevent the lights from turning on and the laptop too? Is it the DC connector? How can I know?
I hope someone can help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Dead batteries can leech enough power to keep a laptop from starting. You can firstly try removing the dead battery and then starting it from the outlet power.
If there is sufficient electrical connection, the multimeter will beep, or else it would probably mean that power cords are faulty.
Otherwise check out these methods and if any of them works.
https://www.minitool.com/data-recovery/p...
Please keep me updated, thank you!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thank you for your time and aswer.
People already reported that the laptop won’t start with battery disconected:
https://superuser.com/questions/1237751/...
https://rog.asus.com/forum/showthread.ph...
Nothing relevant in the provided article though.
@jpfroud Sorry it didn't help, but please do keep update the latest progress.
댓글 달기
jpfroud, failures like this are difficult to diagnose. You would need a schematic and board layout to determine what is going on. I suggest that you start off with replacing the battery. Should further troubleshooting be necessary you will at least have a known-well starting point.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jpfroud 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 590
