주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2009 / 2.26 GHz Core 2 Duo 프로세서 / 교육용 모델
16 질문 전체 보기
Any PGA478 compatible CPU's for My iMac Model?
I currently have a p7500 2.26 GHz in my iMac. I was wondering if there was any compatibles. I’m looking to upgrade the CPU to possible max performance.
I’ve looked online and it says supposedly that my CPU is socketed so I should be able too upgrade it.
I’m just not sure if Apple has locked the firmware to my specific CPU or only the CPU’s that they used in their mac models
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Your systems specs: 20" iMac Core 2 Duo" 2.26 (Mid-2009)
The CPU in this series is a Core 2 Duo Processor P7550
thanks, although im not sure if i were to get a better same socket cpu would it work? im almost positive that the cpu was socketed.
The issue is not if the CPU is socketed or not. What are you going to install? There just isn't any TDP 25 Watt CPU's that's any better than what your system came with.
i just wanted to reduce lag sometimes. its usually fine though.
댓글 달기
답변 1개
선택된 답변
Sadly, your system is limited to Core 2 Duo CPU’s and ones that only use 25 TDP.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
thanks for the heads up.
댓글 달기
귀하의 답변을 추가하세요
Stephen Whalen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 119
