이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 4개:
ok that could be due to a bad power supply or a bruned fuse (there is a fuse built into the wii i noticed) id try useing a multimeter and use the dc power mode and see if theres anything (im also not sure the voltage)
keith s.b 의
Dl you have a multimeter?
Andrew S 의
how bout we start easy dose the red light trun on? on the power button
keith s.b 의
My doesn't charge neither does it turn on, so if you get the solution please tell me
Encrypted 의
