주요 콘텐츠로 건너뛰기
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
39 질문 전체 보기
My phone thinks the down volume button is pressed
I own a xiaomi red mi note 8.
I was listening to music normal and it started lowering the volume by itself. I tried to get the volume higher a few times (pressing the up volume button or using the screen) but it kept going all the way down.
So i turned it off and cleaned it a little bit just in case something was bothering the button from the outside, or if the system was stuck. Then when I opened it and it still thought that the down button was pressed so it sent me to fast boot. Somehow I managed to boot it properly and now it seems to be okay, but i think it will happen again.
Is it a hardware or a software error? if there’s nothing I can do about it I might need to buy a new one.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 6개
This is what's happening to my phone now. It's Redmi note 7 btw. :/
I start to think that I need to switch to another brand. Xiaomi sucks :’(
It’s the second time this happens to me. The first it just went away in a matter of hours but now it’s really irritating me. It won’t go away. The Google Assistant fix doesn’t work for me either, ugh!!!! I can’t live without music and videos so this is annoying
I have the same problem holding the volume down button even though I haven't touched it
My phone is Black Shark 4
It works! Thanks for saving me from all the hassles. I'm dumbfounded
Change the volume flex and try.
댓글 1개 더보기
댓글 달기
답변 7개
선택된 답변
I know it's late for answer but i was having the same issue and i hit sound up/down button to table 2-3 times and it fixed :D
해당 답변은 도움이 되었습니까?
점수 91
댓글 102개:
No way that worked for me too lol. Made an Account Just to thank you. :)
Lol, the same . Why does it work xd??
wow mate, thanks for your answer, it literally solved the problem
Man, it really worked. I almost gave up and buy another phone. Thanks a lot
Yeah, that worked for me too. Even my phone entered fast boot mode multiple times and the volume went all the way down to zero on its own.
I thought it was a software bug and soon had made my mind to install custom rom or so. Hitting the button (gently) literally solved the problem! Thanks!
댓글 97개 더보기
댓글 달기
For people who has this issue and hitting table doesn't work, i found an app named 'buttons remapper & combinatin' by 'Irishin'. You should download it, then give permission and then click + button in app, choose the button with the problem for me it is 'volume +', choose 'do nothing' for the action and enable 'block system action'. From now on my volume up button is not sensing anything. For increasing volume , i will use volume down button to see the volume window on screen then will use touchscreen to turn the volume on.
해당 답변은 도움이 되었습니까?
점수 9
댓글 3개:
Hey there 👋
Made an account just to say — Thank you. This bug has been following me for nearly a year now. No idea why it started, but honestly, this little mf annoyed me quite a lot, and as I can see, not only me 👀
Anyways, glad I haven't stopped searching for a solution 🤝
Thank you so much for this solution! Banged the volume button several times already, but this one you suggested is what worked!
Just made an account, too to let you know how grateful I am! Thank you so much!
This works best for me so far, thank you so much. It was suddenly not working (said remapper is malfunctioning) but I reinstalled it and works again. I've tried to solve this by pressing the middle space between two buttons and didn't work but this app did!
댓글 달기
I had the problem there i smacked the phone on my bed and i was hitting my phone without any reason then i found it was a software problem. After knowing it i started searching for a genuine solution but i didn’t find any but after a lot of reaserch i just solved my problem by reboot.
Redmi volume button problem solution
Hope this will help you also
해당 답변은 도움이 되었습니까?
점수 5
댓글 1개:
Fixed by hitting lightly on bed ..great
댓글 달기
I had the same thing. Just smash the volume button it 3 times at the table and it will be fixed
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Worked perfectly
Perfect working
I cannot believe that it worked. Thanks a lot.
댓글 달기
I got a xiaomi redmi note 8. And today I experienced the same thing and it started when I was playing league of legends: wild rift and it becomes a hindrance in my game as it blocks the buttons I use to play the game. If you want a visualization; the volume always appear in the screen, every second so it doesn't go away. I tried restarting the device but the options to "airplane mode";"silent mode";"restart";"shutdown" don't appear. So, I long press and the device shuts down. Then when I try to open it go to Fast Boot. I tried doing what Mustafa said and in addition tried to clean the earphone slot with cotton buds with 99% alcohol. After that my phone goes back to normal. (I already have pried open the back of my device to try to fix the buttons itself but don't know how to get into the buttons itself.) Hope this helps the others before they pry open their device.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Volum botten is not working
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I put a cloth on my finger and rubbed it on the volume buttons making them click again and again it fixed the problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
whyyy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 91
7일 전: 557
30일 전: 2,254
전체 시간: 65,946
