주요 콘텐츠로 건너뛰기
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48 질문 전체 보기
No battery charge light, but battery reports 100% yet doesn't work
Slightly different than what others have been experiencing. No battery charging indicator light illuminates when plugged into AC power. Battery reports 100% on the indicator and shows good charge after running a battery report…so it seems like its recognized — yet when I try to use it without AC power the computer immediately dies. I’ve tried the uninstall battery method and it didn’t work. Neither did leaving it plugged in to trickle charge. I tested the power at the battery connection point on the motherboard. Without battery attached but AC adaptor not plugged in, I only got one reading: pin 7 at 3VDC. With the AC adaptor plugged in I got readings on pins 3 and 4 of 2.7VDC, pin 5 at 0.4, pin 7 at 3 and pins 8 & 9 at 0.7VDC. Worried that its a mobo problem vice a battery problem but looking for any suggestions. Thanks in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
laptop toshiba in no battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Denny 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 74
