주요 콘텐츠로 건너뛰기
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
130 질문 전체 보기
IPad won’t power on
Hi,
I have an iPad Pro (a1584 12.9).
the device will not power on and my usb amp meter goes to 0.9 then back down to 0.
when the screen is attached there is small backlight flicker but nothing more.
thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
hello wbeatty16,
0.9A is normal charging current for iPads. If drops down to 0.0A in cycles it can means there is a short circuit on loading path or power ic has a problem. Change the "lightning" cable original first. If it doesn't get better, you have to take it apart and see what's going on inside.
Such iPad problems can come from different origins and affect several different sub-systems. It will be crucial under what circumstances it happened for the first time. If you know microelectronics and can solder, check and replace the usb regulator (1610a3) then the DOCK tape. If not, find a good repair service.
  • regards,
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
wbeatty16 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 171
