Broke tiny bottom connector that holds the trackpad ribbon
I accidentally broke the tiny connector that holds the trackpad/keyboard ribbon in the bottom. Now my MacBook won’t powerup. I was trying to replace the trackpad ribbon. can you please advise what that part is called? and how I can fix/replace it? Your help will be greatly appreciated.
Update (12/31/2020)
Here is an image :
not sure if the image is visible. i am new to ifixit. here is an example: https://d3nevzfk7ii3be.cloudfront.net/ig...
The cable slides in and there is a small black connector that clamps down..
좋은 질문 입니까?
댓글 5개
You can use kapton tape to hold the cable in place instead.
Ryan 의
Thanks Ryan! Really appreciate your kind responses. My mac stopped booting up or charging after this broke up, is this normal? it didn't make sense to me.
Its Me 의
No problem. That does seem odd.
Just to clarify only the ZIF Connector broke right? That's the flap that you flip up/down that holds the flex cable in place.
The ZIF connector shouldn't have any bearing on the Mac booting up as far as I know. Did you disconnect the battery before replacing the cable?
Ryan 의
Yes that is what is broken. I didnt disconnect the battery.
Its Me 의
Ryan, is there a way to revive my mac? I think i understand now what I messed up.
Its Me 의
