Power Supply Board Voltage Readings
My Samsung TV UN50H5203AF suddenly went black . I had sound and the power on off lights worked but no picture. I removed the back panels and tested the led lights. Only 8 of the 60 lights were still good. If I replace the led lights with new strips will that solve my problem?
I did some readings on the power supply board at CNL 802 where the led connector plugs into. With the led connector unplugged In Standby mode pin 1 read 260 volts all the other pins read 0. Power on mode pin 1 read 382 volts and all the other pins read 0.
I took readings at the CNM803 plug in standby mode. UN pin -2.3 v, PWM_BLU-3.3v, PS.ON -4.4v, GND-0v, GND-0v.
There is a stamp on the board that has STB:8V ON 13V in a box pointing to JP817 wire. My readings on this wire were STB:11.4V and ON 12.7V. Do these readings show a good or bad power supply board?
좋은 질문 입니까?
댓글 1개
Hello, I hope you are doing Well.
The backlight of my tv is not working.
On the CNL802 I got those readings:
PIN 1+: 225V
PIN 1-: 0V
PIN 2+: 0V
PIN 2-: 0V
(Same readings whatever if I plug/unplug the backlight from the power board).
I should have also voltage in the PIN 2+ no?
Or is it the normal behavior of a power board
Great thanks
Ted Karter 의
