Whole Keyboard stopped working
Hey! About a two weeks ago I spilled some soda on my Macbook Pro 2015 13”. It really were just a few drops on the top-left side of the keyboard so I don’t think it harmed anything really. (What do you think? The problems started to arise about 1 1/2 weeks after the accident?)
Anyways, a few days ago I saw that my keyboard suddenly stopped working. When it happened, I started randomly typing on it and after about three seconds it worked again for a few minutes. (The WHOLE keyboard stopped working, power button was completely fine though) This happened for a couple of days on and off. Eventually it stopped working completely.
So I opened my machine up to see wether there was any water damage visible. Took the motherboard out, lifted up the “background lights tab”, but nothing. I didn’t see any water stains whatsoever. So I built everything back together (I think I saw that the keyboard cable was a bitt loose when I opened it up, so I put it back in correctly) and it did work again… for one day. The problem arised again, but only very rarely (once every couple hours for a few keystrokes)
So… I did some research. Apperently the power button is a seperate port on the connector, which explains why it worked.
So I am now searching for the broken part and I am not even sure anymore if my soda accident had anything to do with it (It was 1 1/2 weeks ago, the computer was everyday in use and only after that the problems arised. Besides, the WHOLE keyboard stopped working not just individual rows)
I narrowed it down to a broken touchpad-to-mainboard connector or the USB Controller. Floating Ground maybe? Or even missing PP3V3 or PP3V42? Power button still works, and is low active after all, but maybe isn’t as sensitive. Measuring anything isn’t going to work because the problem happens so rarely.
Thank you guys so so much!
Update (20.01.2021)
Here a screenshot from coconut battery
좋은 질문 입니까?
댓글 1개
Lets rule out your battery first, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Dan 의
