주요 콘텐츠로 건너뛰기
Repair guides and information for the Nintendo Switch Joy-Con controllers.
97 질문 전체 보기
How do I reattatch a joycon rail
so i broke off my right joycon rail and have no modding experiance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Depending on how you broke it you might be able to but it back on. Is it possible you can attach a photo of the joycon?
same problem here. are the two flat cables from the rail intact like mine are?
댓글 달기
답변 1개
Depends how it’s broken. Did you drop it? Or pull it? If the rail is still intact, you have to carefully open the Joycon, put it back and close it. For that you’ll need absolutely a TriWing (Y head) screwdriver.
If the rail is broken, you’ll need a new one.
Same thing if it’s the rail on the Switch’s side.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
R3_DACT3D 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 126
