Colorful screen glitching -> broken display + workaround
My parents Macbook Pro A1502 recently developed some heavy screen glitching / colorful flickering all over. Here’s what I checked so far:
- Issue starts right after boot to full UI, more present where there is (mouse) movement.
- Rarely there are a few seconds where everything looks fine, fullscreen videos on YT weirdly seem to be ok.
- Still glitches in red/green/blue if I set MacOS UI to grayscale
- Screen also looks mostly fine during startup or diagnostics but sometimes shows the issue during the software update screen
- The problem is not present on an external display (HDMI) or in screenshots
- If an external screen is connected via HDMI, the flickering/glitching on the internal screen and the external display stops (HDMI cable w/o a device connected on the other end does nothing, though)
- elementary OS does not show the same problems
- Diagnostics additionally show NDC001, “CPU System Agent Core” in iStat Menus sometimes reads 0˚ (which I believe the machine might have already shown when I gave it to them 3 years ago, so probably unrelated)
Any ideas what the problem might be and how it could be fixed?
And what worse symptoms could come next, if any?
좋은 질문 입니까?
댓글 1개
Pretty much exactly the same issue was described here:
What is the cause of this display glitch?
The glitch pattern looks a bit worse and changing the logic board did not fix it.
Markus 의
