주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
Why isn't my touchscreen responding after digitizer repair.
LS,
My iPhone 3G stopped responding to my touch. Looking on this website i figured i had to install a new digitizer. So i replaced it using the front panel kit.
After i fixed this problem it still doesn't work. I think this problem could be a software problem, but i wouldn't know how to fix it.
Do you have any ideas?
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
What makes you think the fault is software related?
Did you notice the issue after an update / jailbreak attempt?
Firstly, try resetting / restoring to see if that works.
If not, then I would say disassemble and check your connections, especially cable 2 at the top end of the phone.
Did you definitely buy the right version of touch and fully secured it?
Sounds stupid but you wouldnt believe how many I repair with the wrong touchscreens on or the cable only half way home.
Hope I helped.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
+absolutely agree!
Well, i think it's a software problem because with my old digitizer it worked after it was 'broken' for a while.
I already tried the restoring/resetting, but it doesn't work as well.
I also bought the right hardware to fix my iPhone with, so that couldn't be the problem as well.
The only thing i could do is check the connections, but i don't know if that's going to help.
Thanks for the questions!
댓글 달기
귀하의 답변을 추가하세요
lesterverhoef1 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,099
