주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
When powering on apple logo appears then screen goes black
Hi All
I've replaced battery in this ipad and now when I power up the apple logo appears on the screen for around 2seconds the screen goes dark, I'm saying dark as I still believe its powered as when I press and hold the power button it goes black there is a definate change.
Any help and advise would be helpful….its apparent that is something I've done. Would be good to know what!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Can you put the iPad in restore mode? Try to press the power and home buttons at the same time for about 20 seconds, until you see the “Connect to iTunes” screen. If you can do this, most likely a factory restore via iTunes will solve the issue.
If you cannot put the iPad in restore mode, then the problem is way more serious and very likely in the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Of course, try to put it in restore mode while connected to the computer or the wall outlet.
댓글 달기
귀하의 답변을 추가하세요
Barry moore 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 14
