주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
First generation, based on the Ford C1 global platform.
windshield washer reservoir is leaking
I have a 2007 Mazda 3 and the windshield washer reservoir has been damaged by hitting a curb. What is the easiest way to replace it? The bumper appears to be undamaged.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Nothing easy about it....:-(
WASHER TANK REMOVAL/INSTALLATION
1. Disconnect the negative battery cable.
2. Remove the front bumper. (See09-10-8 FRONT BUMPER REMOVAL/INSTALLATION.)
3. Disconnect the windshield washer motor connector and windshield washer hose.
4. Disconnect the rear washer motor connector and rear washer hose.
5. Disconnect the washer fluid-level sensor connector. (Vehicles with the washer fluid-level sensor)
6. Remove the bolts and nut, then remove the washer tank.
7, Install in the reverse order of removal.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
bobbieblackmon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 34
전체 시간: 3,924
