주요 콘텐츠로 건너뛰기
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 질문 전체 보기
SD Card Door Won't Stay Shut
The little flip up door that holds the SD card in place won’t hold the SD card in place.  Gorilla tape only works so long and not very well.  Is there a fix for that little annoyance you can suggest?  The device works perfectly fine otherwise.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hello Gregory,
I would suggest maybe duct tape and put a lot of it. That should help keep the door shut. I cannot find a way to replace the door but if you want, I am not saying to do it. Pull out the flap and put duct tape over the place where the door used to be. If that does not keep the SD Card door in then I am not sure
Happy Fixing!
-Javen
@tacofixes
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I was hoping to not have to just add more tape. thanks.
댓글 달기
귀하의 답변을 추가하세요
Gregory Redick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 132
