주요 콘텐츠로 건너뛰기
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
82 질문 전체 보기
Is there any way to change or repair the ribbon cable?
My screen has white vertical lines and is lacking of colour intensity everywhere. I already did the self diagnostic test, restarted it, reinstalled the os. I really think there is a problem with the flex cable. On ti 83 calculators it was possible to solder cables to replace the ribbon cable, is it possible on ti 84 plus ce?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
What about for ti83?
댓글 달기
답변 2개
가장 유용한 답변
Thanks for doing all those troubleshooting steps, that really helps me out!
Unfortunately, you can’t repair the ribbon cable the same way as the TI-83 family since the CE’s ribbon cable is significantly smaller (you can see it circled in the teardown). The community has been unable to find a compatible LCD you can buy separately, so the only way to get a new LCD is to buy a donor calculator. Fortunately, every TI-84 Plus CE (or TI-83 Premium CE) display is compatible with each other. Just be warned that it is not compatible with the TI-84 Plus CSE’s LCD.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The ribbon cable is attached via a connector that has very tiny solder points. You could try just getting a new screen from another calculator with a different issue, since getting a replacement screen is almost impossible.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
domsflyon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 7
30일 전: 18
전체 시간: 820
