주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
업계 최고의 노이즈 캔슬링 기술과 편안한 착용감으로 찬사를 받은 Bose 최초의 무선 노이즈 캔슬링 헤드폰입니다. 2016년 6월에 출시되었습니다.
Replace the micro USB port to a USB -C one?
Hi, is it possible to do so? Have someone already done it? I wonder if it is possible to do it easily to not have to deal with multiple connectors. That is one of this headset’s flaws.
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
If it is for power only, as with my DAB radio, you can buy a power only USB C connector - which is designed for exactly this purpose - though you need a soldering iron and a pinch of soldering experience. Google - USB-C Power-only Connector or just look at this ...
https://www.mouser.co.uk/new/cui-devices...
Micro USB being used for anything that plugs in and out regularly was an example of engineers loving their designs on paper. Totally inadequate in the physical world.
의 공유
Personaly I just plugged a micro usb to usb c adapter and glue it in place. Total cost $3.50, No tear down needed and it is completly reversable.
의 공유
댓글 달기
답변 3개
선택된 해법
Hi @alub ,
We would all wish things were that simple…
It is a more complicated than it may seem. The Micro USB connector has 5 pins (VCC, D-, D+, ID, GND) while the USB type C connector has a reversible connector with 12 pins on each side (24 in total) with different data buses and transfer lines.
Even if you lined up the relevant pins correctly it would require quite precise micro-soldering, risking to lose the USB-C reversibility and possible device damage. Not to mention the female socket for the USB-C is significantly larger than a micro USB port.
Hope it answers your question.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Alright thanks for the reply. Infact if this was just for charging I think it would have been simpler. But I noticed that the usb port on the headset also helps for data transfers and updates (possible through bluetooth but faster via usb), it is not only a charging port.
의 공유
This has been done, it is possible and PCBWay can make and assemble the board. An expensive mod, but possible if you want it.
https://github.com/jamesturton/bose-qc35...
의 공유
댓글 달기
Hi,
You might want to see this video : https://www.youtube.com/watch?v=V-vFtiDY...
It explains how you can change micro USB connector to USB-C.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Thanks that is quite an interesting video :) I'll dive into this project when the warranty of the headset would be off :D
의 공유
댓글 달기
It is definitely possible to replace USB port to a USB -C. I did it few times, and all works perfectly
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Alub 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 37
지난 30일: 124
전체 시간: 15,975
