주요 콘텐츠로 건너뛰기
MSI GE70 2PE Apache Pro, manufactured by Micro-Star International, this powerful gaming machine was released in March of 2014
3 질문 전체 보기
Forgot my BIOS Password!
I bought this laptop 4 years ago and only got to use it for 6 months because I set a bios password and cant remember the password for the life of me. I’ve tried everything. I even contacted MSI to ask for help. The C-Mos battery has been out for over 2 years now. PLEASE help me get this beast up and running again! Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 6개
Wait what? If the CMOS battery is out, and the main battery is out, and there is not external power brick connected, it should clear any and all bios settings. Can you confirm that this is the case? As in you have pulled out the button battery cell from inside the laptop?
Also confirm you have done a "clear CMOS" this way and holding POWER button for 15 seconds to insure all power has cleared out of the device.
You might have to restart it after that without the CMOS battery in, and then shutdown and plug in the CMOS battery and start up again.
COMS battery is removed.
@redhighheels yes but can you confirm the other steps I suggested?
I've done everything.
Can you not load a USB in, and choose boot from USB?
댓글 1개 더보기
댓글 달기
답변 2개
선택된 답변
You will need a programmer to remove the password from the bios chip. The easiest way for you would be to purchase a pre-programmed bios chip. You can purchase them for around $20 but you will need some soldering experience to replace it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
John,
I’m confused are you trying to get into the BIOS or boot from a different drive. If it’s the boot options you need, F11 will do that. Obviously DEL is the BIOS startup key for this machine. If the CMOS is still not clearing, there should be a CMOS clear jumper (or pins you have to short out yourself). I wonder if @jayeff can help here.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi @dunc ,
Clearing CMOS does not clear the "BIOS password" anymore on most machines nowadays
AFAIK there is no BIOS password reset or any backdoor method to reset the supervisor password. The only solution is to replace the motherboard or replace the chip on the board where it is stored or maybe contact MSI and send in the board
Clearing CMOS will restore the settings in BIOS but not the passwords.
Security is paramount it seems
I've got a diary and a flash drive (both securely separately hidden), just for all my passwords - I'm getting old ;-)
@jayeff good to know, thank you.
댓글 달기
귀하의 답변을 추가하세요
john 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 46
전체 시간: 6,010
