backlight doesn't come on after shut down
backlight doesn’t come on if i switch on the iPad with power button
however it will come on if i hold down home button and power button together
i did unfortunately unplug the screen while battery was connected
lesson learnt
regards Gerry
좋은 질문 입니까?
점수
0
i would interested if anyone else has experienced this problem and how they resolved it
cheers Gerry
Gerry Golden 의
If you turn it on normally the screen is blank right? When you hold down power and home button it should boot into recovery or dfu, when that happens can you see the connect to itunes thing clearly?
Roman Prochazka 의
when i hold down both buttons the screen appears and operates as normal
but most of the time
turning it on wth the power button the lcd screen works
i can just faintly see the apple logo
just no backlight
regards Gerry
Gerry Golden 의
Haven't worked on iPad 6 yet but it sounds like a blown filter, older models like ipad mini also had backlight fuses. I've never heard of a case where it would come on after using power and home buttons at the same time. If you have a multimeter you could check for continuity across filters around the screen connector, possibly a knocked off component
Roman Prochazka 의
@Roman Prochazka
that's what has me confused
sometimes it works
i did a dock connector replacement which was suceesful
now just need to sort backlight issue
thanks for your reply I'll do what you suggested
regards Gerry
Gerry Golden 의
