주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iFixit에서 제조하고 iFixit.com에서 판매하는 모든 스크루드라이버
T6H, T7H, T8H, T9H, T10H - vs - TR6, TR7, TR8, TR9, TR10
Is the T6H, T7H, T8H, T9H, T10H -bit identical to the (torx security) TR6, TR7, TR8, TR9, TR10 -bit? And what is the reason for the difference in naming?
I’m deciding whether to buy a precision screwdriver kit.
T[…]H:
이미지
vs TR[…]:
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
The only difference is the security screws have a pin so the Torx TR bit have a hole to get around the pin, unlike the standard Torx drivers which don't.
의
Can I use a TR6 bit in a T6 screw?
의
Yes, you may use Security bits in standard Torx screws.
의
댓글 달기
답변 2개
선택된 해법
The difference is the T6H is the torx security bit, and the T6 is the regular torx bit. I think you can use the torx security bit in the regular torx, but you definitely can’t use the standard torx driver in the security screw.
이 답변이 도움이 되었나요?
점수 2
댓글 7개:
My question is if (for ex.) the bit labeled as T6H is the same as one labeled TR6.
의
@Professional Amateur They’re not. The H one is the security bit, the non H one is the standard bit.
의
It's a matter of terminology, just observe the bit itself -- does the Torx bit have a hole in it? Then it's a Torx security bit. T6H (H probably means 'hole') and TR6 (tamper-Resistant) are equivalent.
의
It looks like the answer is yes but no one is giving a definitive answer. Simple is a TR8 the same as a T8H?
의
@oldturkey03 Seems like you are wrong if you look at the post below. And you did not give a definitive answer either.
의
댓글 2개 더보기
댓글 달기
가장 유용한 답변
Hello,
I just bought a set containing T6H and T8H bits and I can confirm they fit the TR6 and TR8 Torx Security Screws from the Mac Mini Late 2014 Hard Drive Replacement instructions. The T#H bits have a little divot in the center that accommodates the nib in the center of the security screws.
Does the "R" in TR6 mean "Regular"? Or does the "R" designate that it's a security screw? I have no idea and I wonder if some of the confusion on this thread stems from that "R". Regardless, the T#H bits do work with security screws.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
The R stands for "tamper Resistant", and all iFixit Torx TRx bits are fully compatible with Security Screws and interchangeable with TxH bits.
의
The R in TR6 actually means Security, according to the iFixit screwdriver database.
의
댓글 달기
답변을 추가하세요
Professional Amateur 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 53
지난 30일: 258
전체 시간: 30,927
