Help Me to Identify a Part in MacBook Pro Early 2011 Motherboard
Hi Friends,
I’m facing a strange issue (after using the laptop for more than 10 hours continuously) similar to this thread. Can anyone identify this component on logic board of MacBook Pro "Core i7" 2.0 15" Early 2011
I’m unable to power on the system, battery is not getting charged but when I hold the power button and plug the MagSafe it works. But still battery not getting charged (tested with a new battery also).
I scanned the Motherboard closely and identified a component which seems to be burnt out. Can someone help me to identify this component and whether is this related the to the above issue i’m facing? And how easy to replace this component?
Image Bottom 2 component below the TXC 20.0 Chip
좋은 질문 입니까?
Showing a picture of ones house won't tell me where your house is located Street, township, county, region and country!
So while you've given us a good picture here, I have no idea where on the logic board you are pointing to.
While the solder joints look a little rough, I don't think that's your problem at this point. Some how we need to get your system to a running state so we can run the onboard diagnostics to see what the system is able to tell us.
Use Apple Diagnostics to test your Mac
Dan 의
@danj Hello Dan,
This is related to the same observations which i mentioned on the another thread but focusses on just on the motherboard and the components .
Not Booting and No display
I even ran the Diagnostics and i don't see any issues there.
Please see attached image on the location of the eroded areas which i suspect.
Best Nirmal
Nirmal Kumar 의
So what is the MagSafe & battery checker telling you?
I was hoping you would have replaced the logic board. At that point or have tried to find someone with deeper skills to fix your logic board.
Dan 의
